In the morning I laminated the 6th (last) lamella of the total of 7 for the front bow of the sliding canopy.
Later I drilled some holes on the rear part of the frame, bolted down the support for the front support.
Therafter I had to cut down the rear bow of the sliding part and make it fit the rear bow. I think I don't need to specially announce, that this will be an ugly impression if the transition from the front to the rear canopy is not smooth.
Took quite a while to make it fit and I had to be really carefull and painstaking not to take off too much in length.
At the end I was really happy with the result. I will drill the bow to the connectors at a later time.
